The Waterside Inn, Mountsorrel Loughborough - Added to Everything Else in East Midlands
I parked at The Waterside Inn which has plenty of space and even has an over flow car park in the neighbouring fields. There is a footpath along side the canal which will lead you away from the pup and crowded people making it safe to take of with 250g drone or bigger, plenty of space to use as they are meadow fields.
And when your finished you can have some refreshments at the pub ,that’s what I did and the do a lovely gammon steak.
https://www.watersidemountsorrel.co.uk/
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 06/08/2022. It remains the responsibility of any pilot to check for any changes before flying at the same location.
