This is a 8K 360 degree VR video I recorded at Rudyard lake, Staffordshire. Listen to all that bird song !
You can look in all directions.
If you have a good enough system click on the gear icon and set the playback quality to 4320s 8K
If you don’t own at VR headset don’t worry, you can still view it but the effect won’t be the same. On a desktop pc the video will have a control pad in the top left that allows you to move the view around with your mouse or you can drag the view with the mouse.
If you view the video on a Smartphone via the YouTube App then it will move the viewpoint around depending on the physical position of the phone, rotate the phone to landscape mode and it will fill the screen for better viewing. You can also put the App into Google cardboard mode if you have a Google cardboard VR system to pop your smartphone into to simulate a VR headset.
