Well don’t forget to change your plane back to beginner or intermediate mode when you can’t fly manual…
What is the right hewar to replace this with, is it easy and what’s the best glue for these polystyrene style planes? Guess most of the planes I see are more glue and tape than polystyrene after a while so best to invest in some!
Yith
21 June 2022 21:30
2
That looks bend-backable to me. A couple of pairs of needle nose pliers…
Its worth a try…
As for glue @Steviegeek set me on UHU POR…
Cheers. Also need the little clip for the prop too as that’s snapped a little
Yes will have a look for stls
Assume they are the same.
Yith
21 June 2022 21:57
9
They look like your picture and seem to be the same manufacturer… Come into stock on 24th… so worth a wait, or try to find on Bangood/Ali…
Didn’t realise was same make tbh!
Yith
21 June 2022 22:01
12
All the spares you could need for all the planes… at least listed, if not in stock…
Doesn’t actually say volantex anywhere on box or manual hense thinking different. Know eachine do similar too
Yith
21 June 2022 22:06
16
They’re rebadged with several names… they’re the same.
Actually comes with a spare prop saver so just the gear box. 6 quid not too bad.
Yith
21 June 2022 22:12
18
Yeah mine has the same spare prop saver in the bag as well…
https://cmldistribution-uk.shptron.com/c/tools-accessories
Ergh their site keeps refreshing isn’t nasty, cant scroll down!
Another +1 for UHU POR, PM and I’ll send you a tube if you like.
