I run an iPad Mini on my controller, and all was good. Until one day when I hooked up as normal and the Go app reported a fault on my SD card.
I tried to format it, and got the same error. I tried several other cards, but all had the same error. Everything else seemed ok - the camera & gimbal worked (in as much as the iPad displayed from the camera). But I just could not record. In desperation, I factory reset the Mavic - and was met with a gazillion errors. And still couldn’t record or even take stills.
Facing a return to the shop for replacement/repair, I was pretty fed up. The next morning I tried a different USB cable to the controller. And the whole thing worked like a charm, straightaway. I tried the cable I’d used previously and there was the “SD card fault”.
So beware of unbranded cables. I’d never guess that a cheap USB cable could create such a bizarre effect - but it did. I’m passing this on in the hope that others will remember this if it ever happens to them.
Thanks, RaRa.
I should explain that I bought a couple of right-angle USB-C males so the cable is all neat and tidy when flying. One worked just fine, the other was obviously made by Satan’s Little Imps.
Also another vote here for both TOWAYS and Anker cables. I’m an owner of both, slightly leaning more towards the Ankers but yes, both fully recommended after some equally as dodgy experiences with cheap eBay right angle cables.
My issues were more around disconnects though, what you’ve described @PsychoTeapot is bizarre!! A proper red-herring of an error!!
Thanks to one & all for chiming in. It’s interesting to find the brands that people recommend. Though my post was more to do with the bizarre nature of the error. I’m no slouch when it comes to various tech, but never would’ve put the problem down to the faulty cable. Well, until now.
