Air 2 / 2S battery charging station
A solution to a problem that doesn’t really exit, except if you are like me with three Air 2 batteries, a charging base and a lost power pack - I took the obvious step of getting a complete Air 2S flymore so I could charge my existing batteries.
And, not to lose the means of charging again, I printed tis wee unit to keep everything together. Bright green so it’s easier to find in the hoarder’s nightmare that is my house.
https://www.printables.com/model/902968-dji-air-2-air-2s-charging-station
The files need rotating to sit on a plate to print - I’ve done that for you:
mod battery charge stn.stl (25.4 KB)
mains cable tucked away in box
mains tucks behind power brick for storage (Not shown - USB cable, similar stowage)
three-way charge base slots in place
NOTE:
The cables - mains and USB - take a sharp bend to fit in the case but you won’t be disturbing them once in place. There is little chance for air circulation with this design. I have yet to try it to see how warm it gets.
Nice, I like it, well designed.
Ill pack my flir one for the next meet. :wink:
