Air 65 Pro II - slight rattling noise
I’ve noticed a slight rattling noise when the quad is armed but not in the air. I also notice it during flight.
It seems to fly and behave normally.
I’ve removed all dust and hair from around the props, checked no wires are obstructing them. All screws seem to have the right tightness.
Is possibly one of the motors on the way out? Is there a way to tell?
Yeah - could be a motor
Using Betaflight sliders (1 motor at the time - props off) you should be able to pin point to the problematic motor
Check for play when trying to lift the motor bell from the base (if there - you can sometimes replace the shaft o ring to fix it)
Check for a bent shaft (shaft vibrates from side to side when motor is turning) - may be able to straighten it but will be more fragile / need to be replaced sooner rather than later
Can always flush the motor, or strip off the bell housing and clean any dirt or grit out of the motor of you do find a problematic motor rather than replacing it :+1:t2: :slightly_smiling_face:
What like this???
On a serious note, BetaFPV only sell the motors in sets of 4, for approx £35 plus P&P, so you might as well buy another Air65 for an additional £35 and use the defective one for spares and repairs
Fair point. I actually have 2 spare frames and spare props, so I might get the motors, if I have to. The quad still flies normally. It’s just the sound that made me wonder. :person_shrugging:
this is a useful video, but people posting comments about lost C clips is quite funny. https://www.youtube.com/watch?v=KTp9RYtSkgc
I have these (and the related 0802s) on some of my whoops, they’re pretty nice and I don’t have to buy them in sets of 4 when I inevitably break one.
Finding the KV you want can be a challenge but when you’re chucking a whoop together from spares it doesn’t matter too much.
Well what do you know… I took the motors off the frame, gave them a blast of air and removed with tweezers any hair or dust I could spot. I also replaced all 4 props.
Runs a lot quieter again now.
Air 65 II Pro Racing after motor clean
