Very nice work. Was it a PFCO flight for the port of a drone code pleasure flight?
If the latter where did you launch from - it’s somewhere I’d also like to fly.
Cheers,
J
Personal flight. Take off from Shotley Marina .
is that litchi or manual yaw,impressive!
All Litche . I just hit play and watched it happen .
My only issue with such a mission is that I don’t know exactly where the ships will be positioned along the dock so the yaw may not happen at exactly the right spot . I need to work this out. Not an issue with objects that are static .
True,static (landscape) works well,introduce people or their creations and you’re screwed,maybe tap fly allowing you to concentrate on camera?
Brilliant footage .
Great music.
