Just hooked up the Air 2S to my desktop to check it’s all ok and seemingly the Firmware update that happened yesterday via the controller/app didn’t work correctly as the firmware downloaded again and installed this time.
But noticed the Calibration tab in DJI A2 app and thought it would be a good idea to run it through the process ahead of it’s maiden flight.
Ran through the test OK. Top sensor calibration seemed a bit fiddly as the image shows you to hold the drone perpendicular to the screen but the sensors aren’t seen when holding it flat to the screen.
It went through the test and then came up with the -1 -1 Calibration failed error.
Re-ran it 3 times and still can’t get it to pass the calibration.
I’m using it on a 27" 2560x1440 screen with good lighting as I’ve read that others have had issue with certain monitors before, but wasn’t sure if it’s either that or the drone.
Should I be worried that it’s not calibrating correctly or just try another laptop or PC before heading out tonight for a test flight?
