Anybody tried designing Training Hoops?
Morning all,
My wife bought me some cheap training hoops from Amazon for my birthday back in August. While they work, they are only a couple inches off the ground and there are just three of them.
So, two weeks ago I decided to design my own one that I can 3D print. The current thought is that it will need to be printed in PETG as it is strong and can take a bit of abuse. There will be a number of TPU parts like the bolt, nut and bracers that hold the hoop to the stand, and then TPU joiners that hold the stand top and bottom tubes together. I think this is a good idea as if a drone hits the hoop at speed or if the stand falls over, the force will be shunted through the whole thing and could break the weakest part. If there is nots of TPU, I think it will help to absorb a lot of the force (proof though will be one it is fully printed and tested).
My current design has the hoop at 48cm wide (internally) so should be a good size for most drones. The tube sections are 30cm heigh and there will be two of them. I plan though to print some 20cm and 10cm ones and then 10 of these complete hoops. That way I can put them out as a sort of course that you have to go through and each one will be higher or lower than the last and at a different angle. This was I have to turn as well as go up or down to push my skills. If multiple height tubes are printed with different sizes, when they are assembled on-site, you can put together all at the same height or all different, it is up to who will be flying through them and their current skills. I wanted them to be very adaptable.
All of the white/grey parts are PETG whereas the black parts will be TPU.
Top top section has a TPU block that screws into the top, then has a circular base with a notch cut into it. The top height tube then slots over it. The notch stops the top spinning around, and also makes it very simply to disassemble and put together.
This is a view from the top looking down at the height poles. The 4 legs at the bottom put onto the base and then a TPU plug pushes into a hole to stop the legs coming out. The image below only shows one plug on the right leg.
When taking the top tube off you get to see the TPU joining block that will hold the top and bottom height tubes together. Again this is in TPU as my thought is this will be a shock absorber.
You could put more than 2 height tubes and joining blocks together to make this much much higher. The higher though the more chance of it falling over if hit by a drone.
All parts can be separated and everything is 100% 3D printed, so no glue or anything else will be required. The plan is that all of the parts stay loose in a bag when not in use. Then when you want to use it, you go wherever, then push the parts together to make the hoop and stand. PLA won’t be good for this as it can wear over time whereas PETG has some spring, so none of the parts will wear over time.
This is the bottom block with three of the legs removed so you can see how the legs push on.
I don’t want to give any files out yet as while I have re-designed some of the parts several times to refine them, I still don’t have a fully printed prototype yet. Currently I have the below printed. I hope to have a finished prototype by end of next week. Then I need to test it in my garden my pushing it over repeatedly at force to simulate a drone hit & see how it holds up. I hope that on the ground (a garden/field) it will never break, but I can see if it is used on a hard surface like concrete or tarmac that it will break easily due to the very hard surface. If this happens I will try printing it in PETG-CF and PETG-GF to see if they hold up. Worst case PE. All the tubes are hollow to keep it all very light and cheaper to print. If I make everything 100% solid I am sure it will be indestructible, but this would make them quite expensive to print.
I also thought that you could use tent pegs to hold down the 4 legs as this could help it not fall over if hit by a drone. I will be testing this as well with my Neo 2 (well, it has Care Refresh!) When I do I will see if I can take some videos and upload them in here so people can see the stability and how good (or bad) it is.
What do you all think? Has anybody made one before or tried and found it didn’t work? Any advice or thoughts will be gratefully received.
For a scale point of view, this is with a Neo 2 in the middle.
If the design works I will look at creating one or two smaller rings that can be used instead for people that want it to be harder. I don’t think there is a need to go larger than this.
You’ll be going some if you get that angle of attack
Happy Americas Got Talent GIF by NBC
lol. Well you know these Neo 2 owners, they love to fly manual mode going full speed! None of this Avata 2 slow speeds…
Bicycle wheel rims. Hang from trees with bunny cords. Various sizes. Low on the ground, two canes pushed in the soil. Higher, two taller canes and tie wraps.
Available from local bike shop.
Ps… don’t forget to cut the spokes out :joy:
kids hoola hoops mounted on a pvc pipe which is tapered to stick in the ground..
or conduit with the bends from screwfix etc.
well designed, what are the print times and cost per hoop.
Sterling design work and I, myself, enjoy the CAD work as much as the final product. However, there is a danger of having a hammer and seeing everything as a nail.
…is insanely cheap and all you have to print is connectors. You won’t get circular hoops, of course, but hexagons are fairly close.
I will say I am always surprised at how unstable the “gates on sticks” I have made are. Even with “feet” either side that are as long as the risers. I’m an engineer, I should know I need some triangles. :laughing:
I picked up 6x 60cm diameter hoola hoops from Poundland for £1 each, a 3M length of overflow pipe for £5, plus an hour of 3d printing for the connectors. :+1:t2:
They were set up at BM Part 2 in September
Print times I can’t say yet as this is still the first proper prototype. I printed a leg last night and while it will work very well, I think the walls are too thick, so over-engineered. If I reduced the wall thickness it will reduce both the price and print time.
Once I have a working prototype that I am happy with I will happily share the print times, prices and files.
Something that I am concerned about, the whole stability.
Ah those were yours! They were really good. Can you share your connector files with me? I would love to take a close look at them.
I’ll try to find them for you, I upgraded my home Mac earlier last month. :+1:t2:
The hoola hoops have an oval cross section shape, so they were bespoke to them. I made two simple tubes in tinkercard (solid cylinder with a negative cylinder) then resized one dimension to form an oval tube.
Easy peasy
The hoops I set up at BM, were supported using 450mm of vertical overflow pipe then a 5 way connector (see below) with 300mm lengths of overflow pipe for the feet, each foot was then pegged to the ground using standard steel tent pegs.
If you’re setting the hoops up on solid ground, then the feet could be weighed down with bricks, wooden blocks or sandbags
Thanks Json (@TheBinman) for that, that helps me a lot. I remember your hoops took a bit of force from drones hitting them (not at great speed though) and they never fell over. It makes sense now as you had pegged them down, which is what I thought about doing to mine. I do like the idea of using standard overflow piping. That way you aren’t limited to the height of your build volume and you don’t need to print it at all. You can easily cut the tube to your height.
Did you make the holes to take the tube nice and tight so the hoop wouldn’t spin around if hit on the side? For my design I put a block on the inside of the tube to stop rotation.
I found the below at my local Screwfix, not bad £2.88 for 3 meters! I can imaging though that it will be think walls, so at a certain height it will start to bend. Jason, how high did you make yours?
FloPlast Overflow Pipe White 21.5mm x 3m - Screwfix
I’ve got a pair of open pro rims in the ‘I’ll keep these, you never know’ pile. The next time I trip over them, I’ll fish 'em out. Come to think of it, a few inflated inner tubes would be more crash tolerant … hmmm. :thinking:
Vert interesting idea! Would be very light, wouldn’t damage the drone if hit fast & if the whole thing falls over it won’t break.
Found a cheap one (below) a bit large, but the price is certainly right! The only down-side is that they would be black and really you want it to stand out so it is easy to see from a distance away. You could pant it, but it would need to be very flexible paint.
https://www.sealantsandtoolsdirect.co.uk/silverline-bike-wheel-bicycle-inner-tube-26-inch-588145?msclkid=d8c553866f451a7d43af396b8e1e9595
I did occur to me that the colour would be a problem … maybe some fluorescent tape at the Cardinal points? It would still be packable.
You can find loads of inspiration by searching for tinywhoop gates
As mentioned - a common approach is to use those PVC pipes with various connectors - those guys are even making a killing in the states by bundling those with LED strips
https://webleedfpv.com/collections/leds/products/webleedfpv-led-tube-cube-v2-2026
Thanks @Cedric for the idea. I think I need to re-train Google though
