After pestering @OzoneVibe to try and help with the Zante pano that I did he pointed me towards PTgui, so Ive had a little play today and the results in full auto with very little input from me look as good as Hangar.
First off is the original using Hangar
Then this was stitched using the Hangar images in PTgui and uploaded to Kuula
As always I welcome your critique, apologies for boring subject I took the bike out a couple of miles from home to grab this
Hangar takes less photos than Go4, over half as many depending on the quad you are using, Litchi is good if you get the settings right, I’ve only tried 360 panos in Litchi with the Inspire.
I tend to use Hangar to take the photos and then edit the 360 image in either Kolor Autopano Giga, PhotoShop or Lightroom for stitching etc, not done any for a while now though.
ICE works well … as do they all when each frame has good registration points. Manual works OK in PTGui … if there’s something to register manually. LOL
LOADS OF SEA is not an ideal frame!
