hi
These are a few pics of the packaging and props. they look like the real deal ?
They look ok to me.
Thinking about it for longer, I’d be surprised if people were forging Autel props, the market opportunity to scammers is only 1% of the DJI market
Thanks Pingspike
I’ll sleep tonight
Sunday is when I get the replacement so I will know for sure then.
Came home to find the new replacement props have arrived early .
I’ll keep this short. Swapped the floppy white ring prop with new. Test flight 10feet in a hover and its still vibrating.
Put the original white back and swapped the rear right.
It’s hovering, rock steady, I’m am pleased.
Done a few more swapping, cross swapping to find it’s the same prop that has the issues.
This prop looks and the hinges resistance is the same as the others but something out of wack.
A balance issue?
Not the floppy prop after all ?
12feet hover, walking around it and I’m happy.
Wind is not high, but it’s rock steady in a hover.
Pity you can’t but it on a prop balancer. Bit of tape might have sorted that
Excellent news @Salv - thanks for the followup
