Did some flights today and no dramas at all with any batteries or flights. Post flight I was checking which ones to put on charge and my no2 battery flashes three times when the check button is pressed. Nothing untoward seems to be up but its the only one that’s doing it…any idea what it means?
Seem to recall one of my MP batteries did that when it’s well below 25% - same when initially charging - then, when it has a higher charge you get that upward flash to the level it’s reached.
I remember panicking a bit, too.
Woah woah woah…I wasn’t panicking.
much.
