Like the other smaller GPS units I have, I wanted to change the baudrate and update time to 115200 and 10Hz. I have a BN880 with magometer, and after a while connected it gets sats OK (on 9,600, though the default is meant to be 36,400 it’s not).
Using u-center I just can’t get it to stick any settings I’ve changed. Polling them doesn’t give me a result either. Also can’t see the version it’s on like some guides online say you should have! Frustrating!
are you clicking the SEND button at the bottom of the screen to action your selection of ‘save current configuration’ ?
I’ve used this a few times with no worries
BUT also, are you sure you have a actual connection with your GPS module i.e. you have graphic screens open showing sats found but more definitevly the clockface is working.
Yes send and then save. Absolutely. Had locked position and time etc. Think solved it as Mon messages weren’t on. Had to dash out but seemed to be at 10hz and 115200. Will check again later. F4s ok with 115200 and 10hz?
