Has anyone got any experience with getting permissions for events?
I’ve been asked to put together a vid for a St Ives Biathlon and although I could shoot a lot of it away from the Start and Finish areas which will be congested would be nice to get some footage of start/finish.
Wondered if anyone has gone through this with CAA, it is a charity event as well so giving up time for free, don’t think that matters with CAA but worth mentioning
We covered this on my course and I believe that you need Tom apply for an Operating Safety Case. It was suggested getting these can be quite in depth, depending on what you are applying for.
As I understand, an OSC can be for a one off or can be granted on an annual basis, again based on what you ask for. Having an OSC is how much of the filming is done in London, such as reducing your take off from 30m to much less, and distance from buildings and people.
If your intended operation requires an approval with greater privileges than in a Standard Permission, you will also need to provide us with an Operating Safety Case to demonstrate that the intended operation is appropriately safe.
Details are available in our guidance document CAP 722, including the requirements for remote pilot competence.
It seems they can be expensive as the CAA charges vary on how much work is needed. I found this on the fly Icarus site.
Initial Application for an OSC - £1749
£1749 is the baseline cost for an initial application for an OSC + £173/hour for any work required over and above 7 hours.
This will make a lot of people consider the cost implications of applying for an OSC without any prior experience. If you are considering applying for an OSC to get your standard permissions lower than 50m (for <20kg aircraft) then we recommend you contact Open Sky Consulting for expert guidance when writing your first OSC.
I was thinking of getting long extended pole and using with the DJI Osmo Pocket. I think that could be very stable and be used with smartphone on Bluetooth
I get the impression that this is those who go for the OSCs. This is because many get them to significantly reduce take off areas to 5m, significantly reduce distance from buildings etc and to BA able to fly above 400ft. As I understand much of the paperwork is about proving the safety of your equipment and showing your experience of flying.
As I mentioned before, many get them on an annual basis and then you have to renew annually. Our PfCO course instructor has one. He was a professional tv cameraman who then started with drones to include this in services.
If you having regular jobs which require the OSC then it’s worth it.
I can understand it being expensive as it adds that much more chance for something to go wrong.
Do you know if the OSC is a one off though or annual?
