Are you both running modded tilt angle parameters to get the speed up?
Running what ? :rofl: no idea what or how to do that.
Can’t you heat up the props and twist em for a little more pitch?
Glue two together and double them up on each motor. :+1:
Will the triprop from the fpv fit? :scream:
Most have a 5mm hole…
For such a light aircraft it limits itsself well even with a tail wind. Really had to go some to hit this 36.93 today.
Cant you turn off gps assist? Been here before I think.
All DJI (after about the P2) are ground-speed limited by GPS. :frowning:
They are also pitch limited.
I was close to tying string around my M2 and dragging the mini behind :rofl:
Depends what you call limited pitch…?
You can hack the Mavic 2 to 50’ pitch and you can also set the mode switch to 1 if you want to.
Drone-Hacks
It’s free to hack the parameters too.
So, theoretically, if you hovered it in a car at 70mph on the m6, (with the hgv’s overtaking you :laughing:), would the drone stay hovering with the obstacle avoidance overriding the speed limit?
Wonder if a blob of blutack on the nose would help :smirk::grimacing:
:laughing:
Butter on the props?
So then it’s limited to 50° :man_shrugging:
Not 50 foot then :rofl:
Just plugged it in, and there’s no adjustment on the mini 2, it’s maxed out in sport mode. :sob:
I know there’s a video of someone trying to fly the MP in an airliner in flight … and it DID try and reduce its ground speed. :wink:
Well okay I agree with you.
Point taken
