Going to work night shift 6-6. Can I fly during my break? No one about with all other manufacturers closed, so estate is desolated. Would be just straight up and down. Before complete darkness.
Sure, fine by me
But youâll need to provide more information in order to get a more informed response mate.
Are you in an NFZ? Built up area? Flight in line with Drone code? Etc?
All rules met, itâs just the present situation the reason I ask. Have not gone out to by car to fly. Just a gap in my shift, with no one disturbing me.
If youâre not in breach of the Drone Code then youâre not in breach of the Drone Code
As far as the COVID situation goes, I think the only limitation is on travel, social distancing, etc, which you donât appear to be in breach of either. I canât see a problem here (assuming we have all the details).
You can fly. If the area is deserted and if you donât have anisy bird or blinding lights then the chance of being seen is minimal. You just need an excuse if some nosey b*stard challenges you.
âCo-operating with the local police in watching the streets for people. So, what are YOU doing wandering around âŚ?â
If your on your works property while flying, I canât see a problem. Itâs certainly safer than going for a lunchtime stroll down the street.
Go fly, but do me a favourâŚnot Just âstraight up and downâ ?
Put in a bit of a run around as well?
Technically the law only affects the reasons you can leave your home - what you do after that is not specifically prohibited. But donât expect a police officer to appreciate the fine distinction
Well, thatâs that. The bu____rs at work have installed cctv so cant nip out for a sneaky flight. Not a happy bunnyâ:unamused:
Itâs amazing what you could do to a cctv cam with a bit of spray paint provided you know the angle
Or a really bright light shining straight at it?
Thatâs a notveryprettyboy
Or you could just ask your employer if they would let you fly the bird during your break. Just saying.
I asked my employer if I could fly from our car park, as itâs almost deserted apart from the essential workers cars, they had no objection itâs surrounded by cctv as well so told security what I was doing and they were happy. Got a nice flight overlooking a deserted city which wouldnât normally be possible
Glad it worked out. Look forward to seeing the footageđ
Thanks for all the replies. Didnât fly, worked here for 41 years and wouldnât ask them for the time of day. Ah well, roll on retirement and freedom of movement.
