A quad with an xt30 would be around 3" props? An 850mah seems more suited.
1300 4s is a 5" freestyle typically drawing 100a. So you need an xt60.
What size quad is it for?
It should be okay as long as the battery will physically fit okay. It’ll definitely be on the heavy side, though. I think it’ll fly better with the recommended battery.
With the XT’n’ connectors the ‘n’ denotes the nominal current handling capacity of the connector
XT30 = 30Amp
XT60 = 60Amp
XT90 = 90Amp
There is a degree of overlap with the three variants.
In the RF world I always went by the idea that a physical connection is not always a good electrical connection, and similarly an electrical connection does not make for a reliable physical connection.
The more physical connections you have the greater the voltage drop from between the source and the load.
Example 1.
I used to fly my mid sized Hexacopter with two 5200mAh packs wired in parallel (10400mAh) using a ‘Y’ lead and XT60’s. Once in the air I could see via the telemetry data that my Voltage was sagging significantly. Once on the ground I could feel the wire of the Y lead was warm, and asses that the voltage drop was across this wire, as the wire was not of a suitable gauge for the job in hand. So instead I wired the three XT60’s direct to one another and the result was a much lower sag in voltage.
Example 2.
I have two identical IRC Vortex 150 mini quads. However one has a XT30 connector and the other has a XT60 connector. I fly them with identical 4s 1080mAh packs, but one has a XT30 and the other, obviously, has a XT60. Flying both quads in a similar manner I notice more voltage sag with the XT30 than the XT60 connector, and the XT30 connections are warm to the touch, and the battery is much warmer. This is due to the increased current draw due to the voltage drop needed to maintain the power requirement.
Power = Current X Voltage (P=IxV) in Watts.
So to conclude a XT60 with a thicker gauge of wire will be used on a 1300mAh high C rated pack as using a XT30 and thinner gauge will choke the battery’s performance.
Brilliant that has explained it, so in a nut shell the best thing to do is send it back, which will probably cost as much as I paid for the bloody battery but still means Iv still got to by another one…
