I have a quick question if I may, sorry if its an obvious one, having just changed jobs I now have access to second hand 12v car batteries.
Hence while standing staring at these wondering how the hell I’m going to get rid of them I had an epiphany, could I upcycle these and use them for field charging ??..
If so can you buy the leads to connect them to my charger or would I have to make them up ??..
If you do use aseparate battery for field charging make sure it is secured properly. It wouls make sense to make a proper battery box, line with something impermeable and unaffected by acid and secure it to the boot floor. Saves a heavy weight full of acid rushing forward in case of an involuntary sudden stop!
If you really wanted to be self contained you could fit a split charger and recharge the field battery as you drive to and from your flying site
