I want to piggyback a DJI GPS module just arrived today with an already fitted multilink on a Inspire 2 Cendence controller for which I need a hub. Can anyone confirm this Can Bus Hub would do the job? The supplier has said he is not sure.
Thanks.
John B
Often described as a Zenmuse Z15 can bus hub, s far as my limited knowledge goes it is a passive device linking can bus devices, If your devices have can bus plugs then it should work. (Probably. Perhaps )
Seems reasonable it will be the connection needed so giving it a go. Should get it next week so report back but confident it will work. Unfortunately all the kit it advertises it connects to nobody has! Apparently VW Golfs are full of them though - for what I’ve no idea.
