Just a quick question. What would happen if i was flying the pro and moved both sticks down and to the middle ? Would it shut of the props or not ? I don’t want to try it just in case it crashes.
There is/was a setting in GO4 that lets you choose wether CSC works at all times or only if AC is in a fault condition.
By default it was set to only work when in fault condition.
I thought the setting was in aircraft > advanced but can’t seem to find it.
@plazmapete007 This guy does all that kind of stuff… not sure if updates have prevented it now??? Mavic Pro - Mid Air Shut Off & Restart - YouTube
Could be modded firmware.
