I’m confused with the names for the differing remotes, Rc, RC-N1 and so on. Simply put can the remote from my Air 2 be used to fly my mini 3 pro.
I know the Air2 cannot be flown with the Mini 3 pro controller.
(not particularly impressed with the mini controller input compared to iPhone input)
I did start to put together a compatibility chart - until I got to a point where I was getting uncertain.
Best thing is to look at the controller on the DJI site where they list all models each is compatible with.
Heliguy has a simple list …
RC … Which drones are compatible with the DJI RC smart controller? – heliguy™
The DJI RC smart controller is compatible with:
- DJI Mini 3 Pro
- DJI Mini 3
- DJI Mavic 3 Pro
- DJI Mavic 3 Pro Cine
- DJI Mavic 3
- DJI Mavic 3 Classic
- DJI Mavic 3 Cine
- DJI Air 2S
RC-N1 What drones are the DJI RCN1 & RC231 compatible with? – heliguy™
DJI RCN1 & DJI RC231 are compatible with the following DJI drones:
(They are the same controller with different labelling for flight modes.)
- DJI Mavic 3
- DJI Mini 3 Pro
- DJI Mini 2
- DJI Air 2S
- DJI Mavic Air 2
Found this (which I’ve extracted from … Which DJI remote control for which drone? Compatibilities)
RC-N1 or RC-231 | RC-N2 | SC | RC | RC 2 | RC Pro | FPV V2 | Motion Controller | RC Motion 2 | |
Mavic Mini | ![]() |
Mini-SE | ![]() |
Mini 2 | ![]() |
Mini 2 SE | ![]() |
Mini 3 | ![]() |
Mini 3 Pro | ![]() |
Mavic Air 2 | ![]() |
Air 2S | ![]() |
Air 3 | ![]() |
Mavic 2 | ![]() |
Mavic 3 | ![]() |
Mavic 3 Classic | ![]() |
Mavic 3 Pro | ![]() |
DJI FPV | ![]() |
Avata | ![]() |
@OzoneVibe Dave
Cheers buddy, but i’m still non the wiser, what controller i have with my Air 2. I’ve searched all over it for a model number without success
No it doesn’t …
https://www.dji.com/uk/mavic-air-2/specs
DEFINITELY the Air 2.
Close that Air 3 popup window with the X top right.
Anyway - that chart above lists only the RC-N1 and the Smart Controller for the Air 2. You’d know if you had the SC - ergo, RC-N1.
Yes you’re right, you’re dealing with a pillock!
Seems like mine’s an RC-231
Which is also named RC-N1
I have a Mini 2, and mine is definitely an RC-N1, but its labelled RC-231, so its definitely an RC-N1 that you have
So, I can fly the Mini 3 pro with the Air 2 (RC-231) controller but,
Cannot fly the Air 2 with the Mini 3 pro remote (RC)?
Did you not look at the posts I made from Heliguy?
Of course I read it, I was just confirming that’s all.
Thank you
Mine is orange and has four bits that stick out of each corner and it make a buzzing sound as it goes up
In the air then a crashing sound when it comes down. Lighten up,
My RC will control my Air 2S, and the RC-N1 from the Air 2 will control the Air 2S (and the other way round), so I’m thinking the RC from the Mini 3 Pro will work the Air 2.
