DaVinci Resolve v20 - is out of Beta - and v20 Updates
I agree that the fastest drive is always going to be faster, however, using the thunderbolt USB is the best option for me as the render cashe sizes are too big for the system capacity thats available on my main drive and therefore at best warns you it cannot perform the render or even worse crashes the PC.
I will be upgrading my main drive to 2TB going fwd but for now it would be impossible for me to work as you suggest.
Hi @lalex, it looks as though you’re quite new here :wave:t2:
Just addressing issues .. no new features.
What's New in DaVinci Resolve 20.0.1
• Support for Blackmagic RAW SDK 4.6.
• Addressed incorrect media pool clip sorting when added to timeline.
• Addressed voice over issues with multi mono configuration enabled.
• Addressed Music Editor not retaining settings on reload.
• Addressed beat marker display when adjusting Music Editor.
• Audio Assistant no longer applies fade outs at the end of the mix.
• Improved IntelliScript alignment of script and transcribe differences.
• Addressed issue loading linked audio clips in media audio player.
• Addressed occasional speed editor issue adding smooth cut.
• Addressed incorrect subtitle animation when appending words.
• Addressed copied Fusion nodes ignoring process layer settings.
• Addressed refresh issue with object removal when switching comps.
• Addressed multiple OpenColorIO issues in the Fusion viewer.
• OCIO FX now allows filtering of color spaces.
• Improved node cache retention for color changes in other layers.
• Addressed magic mask cache reset in multiple scenarios.
• Addressed incorrect thumbnails for ACES 2.0 timelines.
• Improved handling of packet loss with remote monitoring.
• Addressed issue consolidating BRAW spilled recordings.
• Deleting projects now reliably removes project cache.
• General performance and stability improvements.
Chances are none of us are lucky enough for this new module to be of interest ..
What’s New in DaVinci Resolve 20.1
The following features have been added or updated.
Significantly, lots of Apple Vision Pro immersive video functionality. This is probably Studio version only. Not sure.
Key Features
  • Apple Vision Pro spatial and immersive video workflows in macOS.
  • Direct monitoring of immersive content in Apple Vision Pro.
  • Support for Apple Spatial Audio Format.
Cut and Edit Page
  • Improved easing behavior for multiple keyframes.
  • More consistent easing for curves, keyframes and inspector controls.
  • Improved curve editor for active curves, ease, locked parameters.
  • Ability to adjust curves from the timeline keyframes and curves tray.
  • Keyframes are now displayed beyond clip edit points.
  • Ability to set a shortcut to switch between curve and keyframe views.
  • Curves option to disable auto zoom graph height for custom zoom.
  • Support for built in MultiText character level styling.
  • Support for MultiText indent, align and paragraph level styling.
  • Ability to import CSV files as column-aligned MultiText text boxes.
  • Additional smart reframe mode to affect pan only, tilt only or both.
  • Support for custom guides and snapping in the timeline viewer.
  • Ability to toggle extents for selected safe area overlays.
  • Ability to create subclip from edit timeline in out range.
  • Support for find in media pool for USD based geometry clips.
  • Options to sync media pool audio using in, out and marker.
  • Ability to sync audio for stereoscopic 3D videos.
  • Menu action to move playhead to mouse pointer using the C key.
  • Menu actions for full extent, detailed and custom zoom for timeline.
  • Timeline tab action to load to source viewer.
  • Configurable actions to explicitly enable or disable clip.
  • Audio and video only insert controls in the source viewer.
  • Improved right to left language handling in transcriptions.
  • Ability to view transcriptions for clips on the source timeline.
Fusion Page
  • Support for new immersive option in the viewer 360 Views menu.
  • Support for new immersive patcher tool.
  • Support for Magic Mask v2 in Fusion.
  • Support for caching deep composites to disk.
  • Option to downscale clip compositions to timeline resolution.
  • Improved DoD and RoI support for deep image compositing tools.
  • Improvements for USD Renderer for overscan.
  • Edit individual tool controls from the inspector context menu.
  • Improved shape duplicate tool with style, jitter and aligned rotations.
  • Support for swizzler to create alpha only multi layer outputs.
  • Support for swizzler background channels.
  • Support for regular expression based selection in Cryptomatte.
Color Page
  • Improved color viewer safe area display selection.
  • Ability to switch timeline resolution on the fly from the color viewer.
  • Improved cache retention for copied versions and timelines.
  • Improved magic mask retention for copied versions and timelines.
  • DCTL Support for ACES 2.0 Core.
Resolve FX
  • New ColorTone Diffuser emulates light based lens filters.
  • Natural and strong split tone modes in Film Look Creator.
  • New Split Tone with additional controls.
  • Separate RGB sliders and shimmer controls in light rays.
  • Secondary glow ability in glow.
  • New atmosphere controls in light rays and glow.
  • Ability to regrain skin smoothening areas in face refinement.
Fairlight Page
  • Support for half speed timeline playback.
  • Action to enable focus mode using the W key.
  • Ability to record in 32-bit floating point.
  • Audio waveforms are now accurate when recording.
  • Clip context menu action to regenerate waveform profiles.
  • Faster Audio Assistant analysis with short clips improvements.
  • Audio Assistant option to view the full UI of underlying effects.
  • Dialogue matcher ambience controls and improved wet dry matches.
  • Support for deleting busses from track headers and index.
  • Shift option command for fine mouse based scrubbing zoomed out.
  • Shift and command click to add to selection in mixer.
Codec and IO
  • Support for Blackmagic RAW 5.0 SDK.
  • Faster decodes for URSA Cine 12K LF and URSA Cine 17K 65 clips.
  • Support for decoding and encoding webp images.
  • 12-bit support and custom quality controls for DNx.
  • Support for encoding H.264 and H.265 in MXF Op1A clips.
  • Support for decoding Samsung APV clips.
  • Improved native Windows H.264 and H.265 bit rate controls.
  • New deliver preset for Tencent video uploads.
General
  • Improved layouts for small, dual screen and vertical video views.
  • Improved per-system bin layout retention for multi-user projects.
  • Use shift space to display the effects search dialog in all pages.
  • Ability to search for effects in both English and application language.
  • Clone tool support for xxhash64 checksums.
  • DRT timeline exports now include Fusion media references.
  • Viewers now reflect updates to still images by other applications.
  • Concurrent viewer overlays for DeckLink and remote monitoring.
  • Scripting API support for voice isolation for audio clips and tracks.
  • Support for Electron 36.3.2 for workflow integrations.
  • New Javascript promises API for asynchronous workflow operations.
  • Support for audio only TS growing files.
A new section in the install routines ..
Bugger!
:frowning:
My PC has slowed down to a crawl lately! Pissing me off!
There’s my problem ..
Oh dear. Not sure whats effecting mine. I only have 16gb Ram and can"t expand, but it used to be ok, when I had the free version. Now I have studio it’s so slow, I have to close it and open it again for it to move the piggin playhead!
This is after dropping down to 720p and using proxies! :exploding_head:
The studio version is one hefty lot more than the free version .. mainly the AI content. Not sure what overhead this has when not actually using an AI feature though.
I use Studio, but on 32Gb of RAM.
All very 2016, unfortunately ..
Very much liking the Shift+Spacebar tool/effect/transition/etc search added to Cut/Edit/Colour/Fairlight tabs in v20.1.
It’s been in Fusion since forever.
Took a while to sort my 7 years of tinkering with keyboard shortcuts to have it working everywhere .. but worth the effort.
No more opening the effects panel and then clicking the search at the top .. as long as you have selected the item, or position, you want the effect added .. Shift+Spacebar and type the name of the effect. #Bingo
I use my Favourites bin for my goto effects, but have used the Fusion list option too. :hugs::+1:
Yeah, favourites works .. but this works quicker and now consistent across all sections .. especially when you want an effect/transition that you know is there and haven’t used often enough to have favourited.
I’ve now removed all the favourited effects in preference for this one solution at all times.
For starters .. you don’t even need to use the mouse.
What’s New in DaVinci Resolve 20.2
URSA Cine Immersive Workflow
  • Streaming from Fusion page to Vision Pro.
  • Support for immersive option in PanoMap.
  • Support for immersive world pose rotations and flips.
  • Render stereoscopic 3D as full side by side or top-bottom.
  • Node stack support for stereoscopic 3D workflows.
  • Support for immersive EXR workflows.
Cut Page
  • Improved replay stinger transition handling in interlaced timelines.
  • Improved replay editor and ATEM switcher feedback cueing replays.
Edit Page
  • Sync lock controls ripple edit independently from auto select.
  • Improved ripple trimming now preserves sync for edit actions.
  • The trim editor now automatically displays when dynamic trimming.
  • User preference to switch to single viewer mode for trim editor.
  • Improved source and destination patching in the track header.
  • Timeline audio menu action to detach synced audio from video.
  • Support for adding and populating custom metadata fields.
  • Support for flattening multicam clips with speed changes.
  • Audio track solo support for the source timeline viewer.
  • Source track destination sub menu action to reset to default state.
Cut & Edit Page
  • Menu actions to move selected keyframes up down left and right.
  • Curve and keyframe editor in timeline now includes actions toolbar.
  • Shift click keyframe editor headers to toggle multiple parameters.
  • Alt click keyframe editor headers to toggle parameters exclusively.
  • Guides support individual colors and lock states.
  • Switch between pixel and percentage when adding or editing guides.
  • Mouse priority for Fusion, transform and effect overlays over guides.
  • Voice over countdowns now support audible beeps.
  • Editing now preserves audio bus automation.
  • Option to ripple delete silence for selected clip.
  • Up to 2x faster transcriptions on macOS.
  • Up to 2x faster voice convert analysis on macOS.
Fusion Page
  • Support for editing custom guides in Fusion viewers.
  • Improved MultiText alignment and transformation controls.
  • Support for animated image inputs for USD tools.
  • Multilayer support for 3d renderer.
  • Multilayer AoV channel support for USD renderer.
  • Up to 2x faster surface tracker performance.
Colour Page
  • New AI based Resolve FX Cinematic Haze.
  • Resolve FX light effects support glow from alpha sources.
  • Menu action to navigate clips using clip number.
  • Ability to reset node color for multiple selected clips.
  • Advanced color panels persist side panel states after restart.
  • Improved HLG viewer output when using viewer display profiles.
  • RCM and CST now use ITU BT.2408 for HLG and PQ conversion.
  • Up to 2x faster Resolve FX surface tracker performance.
Fairlight Page
  • Project settings option to disable soft fades between clip edits.
  • Project settings option to set ramp-to-play time.
Codecs & I/O
  • Support for decoding Apple ProRes RAW clips.
  • Support for encoding Samsung APV clips.
  • Support for decoding Sony ARW images.
  • Support for ARRICORE clips.
  • Single frame webp and gif clips are now imported as stills.
General Improvements
  • Press and hold c key to skim playhead on viewers.
  • Exported DRT timelines now include linked Fusion comp media.
  • Support for current date and time tags in data burn and render.
  • Scripting API support for adding subtitles in render jobs.
  • Scripting API support for setting timeline and media pool clip name.
7.5 GB! Thank goodness for 1GB/sec d/l internet!
I was SO needing this the last couple of weeks : “Support for editing custom guides in Fusion viewers.”
The following features have been added or updated in DaVinci Resolve 20.2.1
  • Paste attributes dialog now retains user selections across copies.
  • Improved magic mask response when adding and deleting points.
  • Addressed paste insert edits not following sync lock state.
  • Trim to and extend edits now honor the J and L edit threshold.
  • Addressed insert with in out not honoring source timeline patching.
  • Addressed jittery playback when scrubbing with go to mouse cursor.
  • Addressed issue with live preview on single viewer set up.
  • Addressed delays with shift click to change edit track controls.
  • Addressed issue with detaching audio from synced video subclip.
  • Addressed marker position when detaching audio from synced video.
  • Addressed MultiText entry issue for Chinese, Japanese or Korean.
  • Addressed issue with getting subtitle text via scripting API.
  • Addressed a context menu crash with split colorspace and gamma.
  • Addressed issue with color picker cursor on SDI viewer output.
  • Addressed search all effects not returning Resolve FX results.
  • Addressed video playback issues in the Fairlight page.
  • Addressed slow bounce operations in the Fairlight page.
  • Voiceover beeps now follow monitoring gain, mute and dim settings.
  • Addressed Fusion viewer guides context menu issue with quad view.
  • Addressed output blanking showing as viewer background color.
  • Addressed decode issues with some Apple ProRes RAW clips.
  • Addressed Sony ARW color artefacts in overexposed areas.
Just a load of tweaks.
Just tweaks - nothing “new”
  • Improved Mac viewer color management for Rec.709 scene.
  • Addressed intermittent jittery playback on Fairlight.
  • Addressed trim edits sometimes removing linked audio.
  • Addressed ripple deletes sometimes unlinking clips.
  • AI IntelliScript now works with multicam clips.
  • Addressed go to mouse pointer not working in the cinema viewer.
  • Addressed issue with go to mouse pointer in fixed playhead mode.
  • Addressed an issue renaming generators in inspector.
  • Addressed issue with blade hover preview in edit timeline.
  • Addressed a crash with some ripple trim operations in edit page.
  • Addressed incorrect track clip counts for timeline subclips.
  • Apply grade from clip now honors node stack grade preference.
  • Addressed issue editing Fusion spline ease in values.
  • Addressed issue when loading some USD texture paths.
  • Addressed viewing named layers from Renderer3D in Fusion.
  • Addressed net rendering of some Swizzler comps.
  • Addressed issues with audio stuttering on some mp3 files.
  • Addressed Fairlight viewer in out controls hidden at certain widths.
  • Addressed issue with R3D artefacts when using motion blend.
  • Addressed EXR to ProRes transcodes losing immersive metadata.
  • Scripting API support to set media location on project creation.
  • Scripting API support to query and apply Fairlight presets.
  • Addressed issues querying some render formats from scripts.
  • Right click on media metadata to copy file metadata values.
I have a question and hoping someone can help. I have just started playing with multi text (Version 20) and am finding it confusing. I have put two texts in my opening, and have independently key framed them to do different things at different times. However whatever changes I make to one transfer onto the other and there seems no way to get around this. Which then makes it pointless? How do you isolate one? I can see the padlocks but have no idea what they are for unless you keep them all locked and unlock the one you want the changes applied to?
I’m in disbelief, looked this up online and no answers. Spent over an hour locking, unlocking, ticking and unticking the different text entries, but any changes made to any keyframe affects all text entries, not just one. That can’t be right surely?
Seems simple enough to me.
Where are you making these changes?
I’m thinking you may be making these changes in the Settings tab?
These impact the WHOLE Multi-Text title, not the individual text elements.
You need to do the keyframing for the individual text elements by highlighting the one you want to change and then change in the Layout tab ..
As in this quick screen grab ..
Timeline 2
