Does anyone know where I can purchase a longer than standard connector (controller to ipad 7) for my DJI Air? The supplied one is too short. Using the standard cable on my iphone doesn’t work for me as I can’t see the screen particularly well.
Can you not just use the lightning cable you use to charge iPad and plug into bottom of controller?
I just bought an Anker 30cm USB to Lightning cable for my MP, and it works a trat with my iPad Mini.
I’m told the full size USB socket is a much better bet than messing with the micro USB on the side.
I only use that for charging, as I run an android phone, and use the same cable.
Good thinking. I’ll give it a try and see if it works, will also save the expense of another cable, thanks
