DJI Battery Killer repairing tool
Hi Sanjay,
Appreciate the reply however, I have already done that. The three batteries are at 12.93V, 12.28V and 13.39V which should be enough?
Best regards, Dave
@ SparkyFPV. Please forward any info regarding the post about the Mavic 3 series touchscreen tool. Is this something you guys are working on actively? Is it available for purchase yet?
I am starting to receive Mavic 3, Air 3 / 3S, Avata 2 and mini 4/5 batteries in for recovery. So would be excited to know if that tool has support for the newer models.
Also, any news at all regarding updates to Battery Killer, and if is open source perhaps.
Thanks for all the info on the site. And also for the occasional links to some of our Youtube videos ( Used to be WeBuyDrones, Now Africa Drone Kings ).
Also, just to mention, for anybody having issues with " Error: Could not perform SMBus read and also Could not write Block to 0x44", this is usually, but not always, related to BMS needing power as SparkyFPV has mentioned a few times. My go to has always been using a bench power supply to either get each cells voltage up to ± 3.5v, therafter, the trick is to connect the positive most tab of the battery ( B+ ) to the + pin on the charging port for 3 seconds. I usually do this with my multimeter in continuity mode, and it will beep, and as soon as the beep sound stops, i know the BMS is " switched on". This works for me every time.
I dont have access to any of my pics at the moment, but if there is a request, i can upload if needed.
Is there a solution to unsealing Mavic 3 batteries with the latest firmware? I have one the came doa. I’ve balanced the cells and need to clear the PF code so that I am able to use it, but I can’t unseal it at the moment.
