So on Tuesday this week, I was bored and needed to run a couple of Avata batteries down but seeing as it was chucking it down outside I thought I would do it in the front room. What could go wrong
Just a little hover for a few minutes should be ok
The first battery is in and Avata is hovering nicely, no problems
Oh why not have a little fly around the front room, and then the kitchen
She flys very well indoors, a bit loud and you realise a vacuuming is needed but everything is ok
On to the 2nd battery
I wondered if I could get up the stairs and around the bedrooms yeap no problems just a little tricky coming back down
Then into the dining room, and this is where the problems happened, somehow the drone got stuck under one of the chairs and started throwing a wobbler
Still not sure exactly what happened but when I pulled it out and flipped it upside down to kill the motors one of the props had lost a blade, which had gouged into the ducting and the motor was burning hot
Fitted a new prop, but on power up I get an ESC error
So this is where Care-Refresh comes in, this is the first time I’ve used it.
Fill in the application online, which takes a couple of minutes. Asks if I want to send the battery back but don’t if it’s not damaged so I don’t. With Care Refresh Express they send a replacement before you send yours back but they put a retainer on your card
The next day I got an email saying the replacement was on its way and a UPS label to send mine back
This morning a brand new drone arrives, sealed in a box with a brand new battery (worth £109)
New charger, new spare props and a USB C-C cable
I’ve not even returned the knackered one yet
Is Care-Refresh worth it, oh yes it is 100%
