Oh dear I bought a 2nd hand DJI fpv as a training tool as I have numerous self built quads that I fly badly !! As wearing the goggles was causing problems . And having the safety brakes ets hover return to home seemed a good stepping stone . BUT I got caught by this forced firmware 0015 sneaky thing … now I’m locked in and fcc hack gone range is non existent and penetration is like sex without viagra !!! Any body able to help
I’m not cool enough to be in the above group but I’ll still respond.
All is not lost. If you are running the Drone Hacks FCC mod you can now roll back the firmware from 015. They posted the details on their website a few weeks ago.
Thank you yes it’s worked drone is now on correct firmware for hack to load but goggles still stuck in 0015 now sure if I can flash to goggles all binds and flies but not sure if goggles and drone on different firmware is ok ???
Not sure how you update/downgrade the goggles.
But the firmware is available here
27 minutes onwards on the above video explains all about the goggles.
Thanks very much I shall watch it again and see what I can do . then to test again properly when the rain stops!!!
Btw I’ve got drone back to firmware ending 0000 but goggles are still on 0015 !!! I thought all had to be on same to fly ? It’s all binding and flying just trying to confirm fcc is actually enabled
Touch the three dots … in top right corner
Choose Transmission tab
scroll down to the signal strength graphs
Many thanks . Just hope it won’t force me into the dreaded forced firmware 0015 Again !!! Thank god tor TBS crossfire on REAL fpv lol
Don’t do it, you will be forced to update again
