Hi
I downloaded the latest DJI Go app today.
Can anyone tell me what the Dynamic Home point does and why I would want to use it
Why would I want the drone to periodically update its Home point at the drones position?
Can it be turned off / on?
I think it’s for active track, so if you travel some distance away from the RTHP you don’t have to go back there
Creaky
18 September 2017 21:29
3
I think it uses your devices gps to update your home point
This sounds bonkers to me!
What if when it periodically updates the home point you’re half way across a lake or something?!
Creaky
19 September 2017 19:30
6
Hopefully you would be on a boat
Looks like it is for active track. It would RTH near where the object has travelled too rather than where you started tracking. I haven’t used it yet to see if it is optional. As you say - not great over water #splash
gavcuk
24 September 2017 05:28
8
Don’t enable that option then?
Also make sure your viewing device has GPS
e.g. iPad Mini 4 (non-cellular) doesn’t unless you use a 3rd party GPS device such as a Garmin Glo
