Selling my unused eND filter for the DJI Mavic 4 Pro as I am moving on to a different drone.
Excellent condition, never flown with it
Full retail packaging; £250 with free shipping. Based in London, UK.
Product Overview
The DJI Mavic 4 Pro Electronic ND Filter (eND 4‑64) is the world’s first OEM electronic variable ND filter for a consumer camera drone.
Designed exclusively for the Mavic 4 Pro’s triple‑camera gimbal, it replaces the need to carry and swap multiple fixed ND8/16/32/64 filters. The all‑in‑one dual‑window optic synchronously covers the 1″ Hasselblad wide‑angle main cam (upper window) and the 1/1.3″ mid‑tele + 1/1.5″ tele dual cams (lower composite window) — delivering perfectly matched exposure across all three lenses with zero brightness jumps when zooming.
Controlled electronically in flight via the DJI Fly app or remote, it offers continuous ND4–ND64 adjustment (2‑stop to 6‑stop) in both Auto and Manual modes. The filter draws power and data through 6 precision metal contacts at its base — no internal battery required. At only ≈5.3 g, it adds negligible gimbal load.
Key Features
World’s First Electronic Variable ND — ND4 to ND64
Continuously Adjustable: Smooth, stepless dimming from ND4 (25% light transmission / 2‑stop) to ND64 (1.56% transmission / 6‑stop).
In‑Flight Adjustment: Change ND strength in mid‑air via touchscreen — no landing, no manual swapping.
Auto Mode: System auto‑selects between ND4–ND16 to maintain the 180° shutter rule (24fps→1/48s, 30fps→1/60s, 60fps→1/120s).
Manual Mode: Fine‑tune to any value within the ND4–ND64 range for precise creative control.
Triple‑Cam Synchronous Dimming — Zero Exposure Jump
Upper Lens Window: Covers the 1″ Hasselblad wide‑angle main camera.
Lower Composite Window: Simultaneously covers the 1/1.3″ mid‑tele + 1/1.5″ tele dual cameras.
Seamless Zoom: Wide → telephoto exposure stays consistent — no manual exposure compensation needed when switching lenses.
6‑Point Contact — Powered by Gimbal, No Battery
6 Precision Metal Pins: Align with the gimbal’s contact pads for instant data & power connection.
Zero Onboard Battery: Filter is powered directly by the drone’s gimbal — never needs charging.
Secure Fit: Rotary latch mechanism — align, twist clockwise, lock in place of the original gimbal guard.
Premium Optical Quality
Multi‑Layer Nano Coating: Suppresses glare, chromatic aberration, and color shift.
High‑Strength Engineering Plastic Frame: Lightweight yet rigid — protects the optical glass.
Hasselblad “H” Mark + eND 4‑64 Engraving: Authentic OEM quality and easy identification.
