Has anyone else had an issue with their Mini 2 where the camera will not come to life, drone connects to the controller and app, gets sat lock and sets home point but screen is black (even when camera settings are adjusted for exposure)?
Happened to me this evening, it happened once before when I was trying to fly at night and I put it down to me messing something up. This time I checked and double checked everything and it only started working after two reboots (of the drone and controller) and restarting the app. Oh and I also reseated the micro SD card.
I think I have the latest Fly version as I downloaded it from DJI directly and the firmware doesn’t indicate any update required.
Also worth checking the cable as I had a cheap link cable and that gave me some problems but you might be using the original DJI one but I was using a tablet hence longer cable
I’m getting the same thing but with an MA2, screen is either black or white, looks like under or over exposure. I’d had thought it might be something to do with switching between the MA2 and the Mini 2.
Checked just now (same stuff running as last night) and it showed 1.8GB. After optimising it went to 2.8 GB.
Indeed, but if it were app related I would have expected everything to be affected or it to not load full stop. I may have had the Go app running in the background, likewise Litchi which could be a possibility if they interfere with each other not 100% sure if they were, but I had used them in the last few days.
Correction: They were both running, I just looked and all three apps were still loaded up, wonder if that is the cause.
In my case it is two different apps; Fly and Go but it could be a similar issue.
They don’t play nice together, I often swap mid air but make sure one is closed fully before opening the other (Litchi do recommend not using while DJIFLY/GO is open)
I had this too - my Mini2 didn’t like the memory card that had been used in my M2P.
Formatted card and then worked fine.
I keep dedicated cards for each drone now.
