I intended to keep this as a backup when I got the Mini 4 Pro, but it seems criminal just to have it sat here doing nothing.
Originally purchased in November 2022 (valid to the 27th of November 2024), which is when the 2 year DJI Care Refresh started, the drone itself was replaced on the 17th of March. Just under 6 hours flight time and 18km flown.
As well as the original box, soft case, spare props, screwdriver, battery charger and three batteries, I’m throwing in a Skyreat hard case.
There are a number of black marks visible on the RC controller and charger - these are from the the black foam in the case. I suspect they can be removed with a solvent (I just tried rubbing them with a lens cleaning cloth) but if you’re going to use the case, they’re going to return anyway…
And yes, I need to get a slightly bigger light tent…
£650 including insured postage or delivery within a reasonable distance of Berkshire where the item is (or Medway, Sudbury, Royston, Cambridge, Norwich or Silverstone if the dates line up!)
