DJI mini 3 Slight cam /drone drift updated to RC V01.03.2000 still the same
Hi looking for help I have DJI mini 3 about two weeks old it has a slight drift I don’t know if it’s coming from the camera ? Or the drone itself it seems when I hover and not move on the screen either that camera or the drone seems to move slightly right very slow, it’s not windy when this happens I have re calibrated the compass and imu couple of times I don’t know if I am doing it correctly. The on screen display shows the drone placed on a level surface and flipped on all sides except camera side, but when flipping to the two long sides, the drone does not sit level like it shows on the image on the remote. When arms are folded as shown, it actually sits at an angle when placed on its side. Is that the correct orientation? | looked for the procedure in the manual but did not find. Please let me know if I’m doing this correctly I have also just updated firmware to see if that helps to RC V01.03.2000 any help would be great
Any video or Airdata ?
No unfortunately I rest the rc cleared data etc I will try take it out tomorrow and video it and share some info, is this a common fault for the DJI mini 3? I got it brandnew about 2 weeks ago now
Not heard aboit this fault before. How many satelites are you locked on to and have you waited for enough?
Also have you calibrated Gimble.
Hi there last time I flew it was about 22 satellites yes I have tried that aswell I pushed auto calibration for the Gimbel I done it in doors would this affect it ? Thanks
Drone needs to be on the flat. Unsure about outdoors for a gimble calibration. It may be worth dropping a message to D J I.
Have you tried a stick calibration? It’s under … > Control.
Hi yes I have tried that I managed to do a small flight and record what it was doing before the bad weather so will upload it to see if there is any solutions before I send it back
Hi managed to get quick video yesterday before bad weather u will see the drift in video 8804f999-20e9-45a8-8336-302d37fc0c49.zip (93.5 MB)
update so I sent the mini 3 back to DJI they have had a look at it and called me today and said the Gimbal&camera modulefault and they will send a new drone out
