DJI RC 2 neck strap bracket
Oh errrrr
Oh err misses, lol
https://www.amazon.co.uk/dp/B0CFKGD6GQ?ref=myi_title_dp
Here you go this is what I’m using with my RC2 and air 3
Thank you perfect . Bought that one
Anyone know what size threads are on the very bottom of the RCcontroller to fit a lanyard to ?
M4 if I can remember right.
Cheers Kirky. I already have a few straps I can use so I’ll look for something to attach them to :+1:
Amazon or even b&q do the ring eye bolts.
Just had a look on B&Poo smallest they do is M6 ( I suppose I could hammer a pair in ) :joy::joy::joy::joy::joy:
Amazon has got them
Just don’t go to deep, I think the hole is about just under a centimetre, put a cocktail stick in & measure the depth, I did know it but I can’t remember :grimacing:
If you know someone with a 3D printer, you can print them, I did as a stop gap, I also 3D Printed a Prop Strap for my Air 3 out of TPU
In answer to the above they are M4 screws, 16mm or 20mm
www.printables.com/model/209281-dji-rc-drone-controller-strap-plate
That’s the hole depth isn’t it, not the thread depth surly .
16mm with the printed plate, or 20mm with the long shanks
I’m on about the the thread depth on the bottom,
8mm ish you don’t want the thread to long or your wind into the controller.
10mm I believe
I think I have two spare if you DM me an address I’ll send them to you
Found this just now, wish I’d seen it before ordering from Aliexpress, I even have Carbon Fibre filament to print them with arghhhhhhhhhhhhhhh
Perfect fit using M2 6mm threaded screws
That’s very nice of you, but I’ve ordered a set off Temu. ( will see what they are like once they arrive from PRC :joy::joy::wink:)
