Can any one advise if they have done any screen recordings with a Lavalier mic as i tried 4 now and none of them work .If you have can you please advise what one you purchased .
Moved your post over to the questions and answers category and renamed the topic so you get more engagement and hopefully a response to help you with your issue. ![]()
I will try recoding again as my RC was set to SD card and according to the video it only allows recording to the internal memory which seems a bit daft but if that’s how it is then so be it .Thanks for posting the video.
Hi I’ve been trying to screen record on my mini 4 pro N2 controller but the audio is terrible. I’ve bought wireless lavalier microphone but can’t get them to connect to my tablet when it’s connected to the controller I’ve tried a USB c splitter but remote won’t connect to the drone until I remove the microphones. Any advice would be very much appreciated. The mics work fine in tablet and phone so it’s not them. T. I. A
does the sound quality get better if the drone is not in flight or far away ? could be that there is some noise suppression at play that’s causing your audio not to sound too great if its trying to cancel the drone sound out. Some of the mic systems out there have this function - see if yours does and turn it off.
Having problems getting lavalier type microphone to pair with RC 2 so I can add commentary to videos. (it;s not a DJI mic )
Welcome any advice with thanks.
