Do I need to include the battery on a DJI drone repair?
Hi there
I’m sending my crashed Mini 2 to DJi for a repair/replacement. Simple question really to anyone whose done this…did you send the battery with the drone. The battery wasn’t damaged far as i know so wondered if there was any point?
Thanks guys
No, just the drone.
I’d even take the props off.
And remove the memory card too (as I learned the hard way :unamused:).
If you send it ALL back - you are less likely to end up with extra/spare RC/batteries. :wink:
Gotcha
If you read the returns policy on the DJI Refresh website you will see that it states not to return a battery unless there is an issue with it.
Many thanks :+1:
Hi All, if you are quite sure that it will not travel by air it could be OK. Sending any battery by air is a huge problem.
