You prep for an early morning flight.
You download offline maps.
You give your drone a birthday and do all those checks just that little bit more thoroughly.
You work out a provisional shot list from Google Earth.
You tidy up your SD cards, format them and make sure they are all ready to go.
You get to the location, confirm it’s deserted and your planned takeoff point is good.
You congratulate yourself quietly on your professionalism and methodical approach.
You get the drone in the air…
…and DJI Go says ‘guess which stupid muppet left the SD Cards on the kitchen table?’
It does. It’s right next to ‘I don’t care if you are five miles from the nearest inhabited building and the local definition of mobile communication is jungle drums and semaphore, I’m still going to make you update the bloody database’.
The joys of a device that’s …
a) only used for the MP
b) has no SIM
c) has no Wi-Fi access point configured
d) remains (almost) permanently in airplane mode to make doubly sure.
It knows nothing about the world outside beyond the brief moment of logging the app into DJI to get it working in the first place …. 15 months ago.
Updates to Go4 … if/when I do them, which isn’t often, are done by side-loading from the .apk copied to the SD card.
If you are like me, and, you have SD Cards fitted in just about anything that will hold one (Phones, Camera’s, Tablets, etc) !.
You may find this Excel Spread sheet useful. to be able to tell at a glance where you have fitted them !!.
I always mark the cards with a fine indelible pen, each with a number on each one.
Alter, as you see fit !.
Correct, I find it easier to have them in the cases (as above) , and in each camera bag.
I now always make sure each drone has one fitted in each
I’ll soon have bloody shares in Sandisk !!
I have one case for SD cards, each card labelled with either D or G depending whether it’s for drone or GoPro. Drone ones also have a number that matches the battery & I swap both out at the same time so I don’t lose all my footage if I lose the drone.
Sadly, the card case doesn’t fit in the Polar Pro soft drone case as well. It’s already got 2 spare batteries, filters, spare props, sun visor and insurance docs in it.
On that occasion, I did a bit of SD card housekeeping and then left the bloody things behind!
