I just started with drones the past week. Today I crashed into a big tree like 15 meters in colchester, and the drone is stuck. I already tried to throw a bottle with a cord on it but I couldn’t reach the top of the tree.
Do you know if hiring a tree surgeon can be a good solution here or does anybody nearby has equipment to retrieve it?
some spectacular drone recoveries are possible…involving heavy bolts, string, cotton thread, a vertical view camera and another drone. Pics are required of the tree, surroundings and drone location within the tree.
I called a tree service. They had to cut down the top part of the tree.
I have the drone now, the battery shows 0 V it was connected during two days. What’s the procedure? Try the drone with a new battery? Dispose of that lipo?
Have you tried charging the battery? If it doesn’t take a charge then a new battery may be worthwhile (depending on cost). There is a possibility of reviving dead batteries but it’s somewhat technical and involves soldering and electronics and other tricky stuff.
We still don’t know what make and model of drone it is!
If you disclose the drone details you may well find that someone reading this and local to you has the right kind of battery for you to try.
It would be helpful to know what drone it is. So one can assist in finding why it went into the tree. Also whether it’s worth spending money to get it back. If it was not expensive then may not be worth retrieving it, but if is a new MAVIC Air Pro etc then yes. I lost a mini2 once and had to write it off as it was completely inaccessible.
