Exploring the Elidir Trail: A Walk Up the Gorge from Pontneddfechan
Heading out early from Pontneddfechan in the Brecon Beacons National Park, the Elidir Trail is one of those walks that punches well above its weight. While it’s strictly boots-on-the-ground territory rather than flying country, it makes for a cracking walk along the river.
Starting at the edge of the village, the path follows an old tramway bed before branching off toward the first major highlight: Sgwd Gwladus (Lady Falls). Tucked on the Afon Pyrddin, this is pure storybook scenery. The river drops around 20 feet over a clean sandstone lip into a massive, dark plunge pool. When the autumn canopy turns gold above the gorge, the contrast against the deep emerald moss on the rock face is hard to beat.
Rejoining the main River Nedd Fechan and pushing further up the valley, the character of the gorge shifts completely. Instead of single drops, you hit the multi-tiered cascades of Sgwd Ddwli Isaf (Lower Gushing Falls). The Welsh name fits perfectly—the river fractures across wide, stepped bedrock shelves, churning through natural rock chutes and pooling over dark limestone slabs. Higher winter flows regularly reshuffle the gorge bed, leaving massive bleached fallen trees wedged right across the upper chutes like natural weir bridges.
Looking upstream from the lower pools, you get a fantastic vista where the stepped cascades lead directly towards the plunge of Sgwd Ddwli Uchaf boiling in the distance. With the northern car park at Pont Melin Fach closed, treating this as a return walk from Pontneddfechan means you get to experience the entire gorge twice—and it looks completely different on the way back down.
It was great to see the water levels somewhat recovered from the dry summer we’ve just had, but they were still lower than I’ve seen over the last 10 years or so of me visiting the area. With the heavy rainfall forecast over the next few days, I’ll be venturing back into the Brecon Beacons soon to re-visit the other main set of waterfalls in the area along and around the Four Falls Trail
Quality :ok_hand:t2:
Lovely photos, thank you for sharing.
I’ve flown Scwd Gwladys, the valley opens out a little just downstream of it and you can get some good angles. Henrhyd Falls, the highest in the area, are a few miles away at Coelbren, and also ‘flyable’ with a sort of natural bowl formation; well recommended! Many of the other falls nearby, especially those on the Mellte and Hepste rivers, are spectacular but a bit overgrown amongst the trees in very steep and narrow ravines, which do not make life easy from a drone-flying pov. Perhaps better in winter, less leaves, and more likely to get late afternoon sun on the falling water. Also worth having a look at are the Galenas & Silica mines and the gunpowder works at Dinas Rock; these have the advantage of being very short distances from the car park. But try and get Scwd yr Eire under your belt if you can, not the easiest access but absolutely phenomenal; the path runs cut into the overhaning rockface behind the falling water, just like Henneth Annwn from LOTR where Frodo encounters Faramir in the books! Seriously, you’ll come home not 100% certain you didn’t dream it!
The big problem is the trees of course, and best practice is to get above them if you can, or stay under the eaves, but it isn’t relaxing and my arse was going like butterfly’s wings… If you’re walking any distance up there in winter, be prepared for thick, slippery mud (take a walking pole) and heavy going, and taking longer/coming back later/being more tired than you’d expected. Don’t leave it too late, it gets very dark very quickly and early under those trees!
We’ve found a Solution for that :white_check_mark::joy:
Thanks @TheJohnster. I hadn’t visited Waterfall Country for a couple of years. I was pretty certain the Elidir Trail waterfalls were under low tree cover and didnt fancy collecting the bits together after a drone/tree interface session(!), but wasnt so sure about the other ones you mentioned.
I seemed to recall Henrhyd Falls might have options as being relatively open in front of the waterfall itself, but wasnt so sure about the others.
I’m planning a return trip in a few weeks after the school kids have all gone back so will take a drone or 2 along with me
Many thanks, @PitchFader
Thanks for the feedback, @WoolySheep
Love me this walk…
Also, there is a “hidden” or “secret” waterfall but, be warned, it takes some extra effort and you should be a capable walker/scrambler. Sgwd Einion Gam (Fall of the Crooked Anvil) is upstream from Gwladys and to reach it requires an extra hour or so of scrambling and crossing the river several times.
To get the closest there is also a mini-drop/fall that you need to cross and access was via a “sheep trail” which I suspect is now gone due to erosion. Either that or you get very wet :slight_smile:
But I took my drone there and spent 2½hrs there completely on my own. For the constant river criss-crossing I’d also avoid after heavy rains. If you Google this, they incorrectly state this has a ledge that you can walk behind the fall on - I suspect they’ve conflated that with Henrhyd falls.
Some shots I took (the 1st with my DSLR and the second two with my drone):
Also, just a minor point: it’s Sgwd Gwladys - so ‘ys’ not ‘us’ but some lovely shots you’ve captured.
Einion-Gam (gam = crooked, as in ‘gammy leg’) is VERY difficult one to get to. That ‘hour of scrambling’ is for a fall not much more than a quarter-mile upstream from Gwladys. One of it’s attractions is that, due to the convolutions of the geology and the stream’s demented meanderings, it faces north-east at the bottom of what is even by the norms of the area a steep and narrow defile, which means that in winter it gets no sunlight at all. You want a frozen waterfall, Einion-Gam’s your best bet.
Haven’t done this, feels a bit risky, but there are footpaths to the vicinity from the A4109 Glyn Neath-Coelbren road that it might be feasible to overfly these falls from.
Thanks. I’m going to pull together a plan for some of the more “off the beaten track” waterfalls to visit and drone once the school hols are over.
I did make a last minute decision to go and do the 4 Falls trail 2 days ago. I woke up early, the weather forecast was much improved so made a dash for the Gwaun Hepste car park. It was still dark when i got there(!) but was walking down to the first one (Sgwd Clun-Gwyn) by 0730. I’d done the first 3 before i saw a single person which was great.
I reckon I could drone fly maybe 3 of the 4 if careful so as Arnie once said, “I’ll be back”..
