Extended Cables for Mini 2 and Huawei Mediapad Tablet
Hi all has anyone bought an extension cable for the Huawei Mediapad M5 Tablet.
I bought the below ones off Amazon but they wont work as the tablet wont connect with the controller.
Any recommendations welcome?
This is the one I bought for my Mini2 and Mediapad. Unfortunately they’re currently out of stock.
https://www.amazon.co.uk/gp/product/B08D63LR7L/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Looks like a very high price for very simple basic leads. Are these leads actually different to those you would buy in a regular electronics store or phone shop ?
Are you certain that the problem is not a configuration or software issue ?
If I remember correctly the one I purchased was around the ÂŁ4 to ÂŁ5 mark. The outer sheath is silicon rubber so a reduced risk of kinks causing breakages.
I have had a look at the software and made sure the debugging was on.
It’s weird as the standard cable works fine just the new ones that don’t work.
I bought the same one and I sent it back as it will not work with the Mini 2
I then got this one same as Nidge and it works fine
Thanks that’s great to know, got another cable coming today so hope that works
Not sure if long enough for you, but I bought this one for use with my Tripltek and Mini2: Amazon.co.uk
Works fine.
You have to make sure you put the correct end into the controller output (has a “two circles” marking on one end like the original).
GC
Thanks all for your comments on this got a replacement as below delivered today and it works fine must just be the first cables that are not compatible even though they say they it will be.
Data Cable, RC Drone Right Angle Type C to Micro USB Data Cable Compatible with DJI Mavic Air 2 / Mini 2 Remote Controller https://www.amazon.co.uk/dp/B095NL826Y/ref=cm_sw_r_cp_api_glt_i_JRV3WCX1EGET33Q3MX7E?_encoding=UTF8&psc=1
I ordered this one and works fine with my mini 2 and Huawei Mediapad M5 Lite
LYONGTECH USB C to USB-C 11.8 Inch Nylon Braided Cable for DJI Mini 2,Mavic 3,Air 2S,Mavic Air 2 Remote Controller,1FT OTG RC Tablet Phone Extension Data Cord(Type-C Connector) : Amazon.co.uk: Toys & Games
Does anyone have a link to a mini 2 cable, USB C to USB C that’s not got a right-angle connector on one end at least? There’s an array of cheap & expensive cables, not all mention data so I’d appreciate a suggestion from anyone who’s got such a working cable.
My new phone case is quite thick and the angled DJI cable doesn’t fit as well as I’d like.
Temporary fix, ordered a USB C 90° adapter so the DJI cable won’t be near the phone case, nor will be the adapter.
