Got out this evening for a buzz about with a couple of packs with the new Mambo
Some good flying there mate. Thought the crossbar was getting it at one point - thats my usual trick
Don’t worry the goal posts get plenty of attention from me usually I need to go through my vids and dig out all the crashes to stitch together
Loved the dive gap at the beginning! Is that using tracer now? You’re looking way more confident on the sticks. Amazing what air mode can do
Haha yeah surprising the difference airmode makes
Cheers mate I feel more confident on the sticks too. Trouble is my confidence is trying to write cheques that my skills can’t cash
My video feed is still breaking up closer than I feel it should though I even turned the output up to “25mw” and it didn’t make a huge difference. I’m going to try adding a capacitor to the battery pads to see if that makes any difference?
Was it ok before you replaced the antenna and pigtail? Have you got the connections tight?
The video has never been that great since I got it. It has the new pigtail and antenna and all fitted nice and tight. The other thing is the vtx is built into the fc. If I can’t get it to improve I will look at replacing the fc and get a separate vtx at the same time I think
What kind of distance should I expect on analogue video on 25mw?
Depends on environment but should get pretty reasonable signal 100 meters maybe a little more.
@Nidge might be in a better position to answer that as he has more experience than I do
Would be interesting to see if someone else’s goggles get better range. It could be my fusion module or goggle antennas
