I’ve just checked and I do have the TALOS installed. I bought the WTFPV PNP version and it comes with a 4 pin cable and not with the 6 pin needed for DJI. But I have got a spare one of those. I can see there is a 6-pin port next to the 4pin port. Phew!
The 100mm right angle/straight version of the coaxial camera cable is not in stock anywhere in the UK, it seems. I’m going to have to get it from overseas, which will delay things somewhat. All good things and all that!
Looks like YourFPV have them in various sizes, uk stock. Shortest is 150mm but I usually get them a bit longer than I need anyway, if you make sure there’s a bit of slack at both ends it makes them less likely to get yanked in a crash.
Those MIPI cables are often first to go in my experience, which is why I have plenty of them in my spares stock at all times …
Connect it through a separate BEC if there ain’t one already on the FC , the air unit lite is max 3S
Most fc will have a 5 and 10v BEC built in , some are plug and play with a switchable solder bridge
This describes the FC as suitable for O4 Air Wide (lower voltage range) and O4 Air Pro (higher voltage range), which seems to confirm that simply a 6-pin wire can be plugged in and no soldering into the 9V pad is required. Also, in the picture you can see the pinout for the 6-pin connector, which has 9V on the left hand side.
All of this seems to confirm to me that I’ll be fine to plug into the port and don’t have to solder the wire directly into the board and use the 9V BEC.
Thought I’d give an update. After waiting for my longer coaxial via Aliexpress for over 2 weeks, InPost managed to lose my delivery. Heaven knows why I’m so unfortunate with logistics companies recently! I must have done something wicked in a previous life.
Thankfully, the UnmannedTech online store has the 15cm straight/angle version back in stock.
Productive evening. I fitted the O4 Air Lite, Rate CNC case and wide angle adapter to my Seeker 3. Betaflight settings have been adjusted. I was able to connect my goggles and DJI Controller 3. All fine so far. Props will be fitted tomorrow.
For a moment I wondered what on earth you strapped to the bottom of your drone. I thought “Well if you take that clock or whatever off the bottom it will be a lot lighter!”. Then I actually looked at the numbers on the clock, and realised it wasn’t a clock…
