absolutely brilliant that! you did a great job on the circling round the lighthouse. I’m assuming that was manually flown around it? the shot down the coast looks brilliant with the clear water. did you have a CPL fitted?
Hi, thank you for that, it was manual because i’m not practiced enough with circling or spiral.
There is no filter, so what you see is the standard finish.
What a great flight. Gorgeous coastline. All lovely stuff, though I might consider a shorter edit and upbeat soundtrack to entice more views/comments.
OK, thanks for that, can I edit it now it’s up or will I have to keep it in mind for future clips?
Hi. That was simply brilliant, thanks for sharing. Looking forward to seeing more in the future.
Take care and catch you later. Peter
Thank you for that
