Is it me, or does this video flicker?
You’ve rendered at 48fps … is that also how you recorded it?
Yes 48fps 1/120 shutter iso 100.
I normally shoot in 48 and then slow to 24 in post as I’ve had some nice results from that.
This is straight out the drone, I just wondered if I’m seing things
I’m not certain - but I think this may be the issue …. most modern screens refresh @ 60fps, and with the speed of the constant downward movement of the trees, you may be getting a bit of a beat between the two. (It’s a reason I nearly always shoot/render @ 30 or 60fps.)
As an experiment, you could try speeding the video in edit by +25% (60/48 = 125%) and re-rendering @ 30 or 60fps. (Depending on which software you edit in - you may have to set up a 30, or 60, fps project initially to ensure frames are not lost in the process.)
Many thanks I’ll try that tomorrow and report back. I’m using Davinci Resolve for editing btw.
Cool - me too. So - set up a 60fps project - import - up the speed to 125% - and render @ 60fps …. would be the best to get the original frames to 60fps.
I’ll be interested to see if that’s the problem.
Ok… the 24 fps still seems to flicker, the 30 and 60 don’t…
This one is 24fps -
https://youtu.be/ZA86e3QPzBU
30 fps -
60 fps -
https://youtu.be/tn2QrdGXKfk
That seems to fit what I was anticipating, then.
Really interesting.
Thanks for posting!
