I had a prompt on my Mini3 Pro to upload/sync my flight logs to DJI, I set this up so a rolling upload goes to DJI. I wanted to look at my earlier flights stored at DJI but can’t find a way of accessing/viewing them, Thanks
The best way is to set up a free Airdata.com account, and sync that to your DJI account.
Thanks, would that pick up historic logs I’ve synced and which subscription would you recomend any benefit going above free?
Look on their site about the increased features and decide if they are what you need and worth the extra.
All the data gets synced, and the addition features will include the flights already synced if you up your level of subscription later.
Yes. Everything on your DJI account.
Thank you
The free version mentioned “Only 100 flights” … but that’s the limit for the number of most recent flights for which you can display the flight data. All your “life to date” totals still include those older than the 100 most recent.
Thanks, I only have the Mini3 Pro on there. It makes no mention of adding additional drones until you get to Gold which specifies 8 drones. Unfortunately it only synced records back to May 2023 so there’s no record from Jan to then. Which level do you have/suggest.
I’ve always cheated and used new email addresses on my personal domain to add the next 100 flights. Keeps them all available for free.
But - used correctly - it should add all flights that have been synced to that DJI account.
Do the flight that are missing relate to a different drone? Any chance you accidentally set up more than one DJI account? (I know I did, accidentally, at some point. )
Also - someone else, a few months ago, was saying they had a load of old flights missing. Can’t recall what the outcome of that thread was. If I come across if I’ll let you know.
It was this thread.
Slightly different scenario, but I’ve just asked if he ever found the cause.
btw - another thought came to me - Airdata sometimes have a good discount for Black Friday, which is imminent. So if you are thinking of a paid subscription, might be worth waiting a few days?
Thanks for all this help, I’ll check in case I did use another email when I originally set up my DJI aacount. One other question if I may, I’ve started my A2CofC with UAV Academy, I did the mock exam ang got 97.5 % (1 wrong answer) I went back to do another mock after a few days without revision (to check my retention !) and got 90%. I did further revision and got a Mock Exam max limit so I couldn’t do any more. I’ve seen on here that some users had unlimited mocks, I know UAV Hub do. Do you remember what it was when you did yours ?
Not done mine yet. Contemplating it currently.
There are probably some threads relating to UAV Academy where it’s mentioned?
I went with the Academy version as there was a Grey Arrows discount £49 but I did look at the Hub version and the training material was much better.
