will try next time, thanks
Hi mockingbird71 have you had any issues at all the reviews on the app some say stay clear becoz of flyaways
Litchi?
I have not experienced flyaway on either, I did put a waypoint in error and didnāt check . but it came back ok. that was scary. I use a mavic 2 pro
I would suggest those flyaways were due āuser errorā.
ie. people incorrectly programming their waypoints on a mission
you should check the route before you take off.
I may give it a try for 20 quid its worth a shot
its so easy to touch the screen and add another waypoint , so be careful whatever you use
Nearly all my mission planning is done on my laptop.
So much easier and more precise.
You can use VLM, too, to create Google Earth visualisations of how footage will look.
VLM = Virtual Litchi Mission.
its worth checking the flight plan at the location , if the maps not up to date there could be obstacles , eg trees and other things that are not obvious on the map from google . just be carful
Iāve managed to use it regularly for over two years without a problem.
I nearly flew a mission that the map was out of date , and there was a tree branch that was farther out than the map said. I now set the route on site unless I know the area im flying in
If youāre flying between, or close to, trees, then Iād suggest a Litchi Mission isnāt a good idea.
it was just one tree that was the problem , lucky I spotted it before it did any damage. wont be doing that in any hurry again . I tend to recce the area before I start the mission , then start it , its safer that way
Are there any third party apps like Litchi for the Mavic Mini? The DJI Fly app is quite basic.
Not yet, DJI havenāt yet released a SDK for the Mini.
But they will
Thanks, Iāll look forward to that.
I might well be the only one here, but I get a slight buzz when my drone heads off in to the (not too far) distance under its own steam thanks to Litchi. The thrill of praying that it comes back / doesnt hit anything / have I programmed it correctly / has it enough battery does it for me.
I get that warm fuzzy feeling when I spot it on the horizon as its heads back āhomeā bristling with video and photos. Its how Iād imagine Iād feel after not seeing a favourite pet for a month or so despite the fact that its only been away for 15 mins.
You should try the āIāll go to the cafĆ© and buy a coffee while I waitā kind of buzzy, and warm fuzzies!
Thats brill! I must try that
Thats next level waypoint flying that is. Thats my goal! lol
