Flight restriction in place
I’m due to be flying near Thurrock on Monday for have seen this notice pop up, can anyone shed any light on exactly what it means? Is it a NFZ temporarily? I’ve called the NATS number but just got the answerphone.
“BO /AW/000/005/5130N00006W001
Q: EGTT/QRDCA/IV/BO /W /000/060/5135N00100E009
2.6 NOTAMs
Type:  RESTRICTIONS (ACTIVATED)
Period: 2025-01-20 09:00 to 2025-01-20 16:00 Sched:
Limits: SFC to FL005
TEMPO RESERVED AREA(TRA) EGTR196 ACTIVATED WI AREA BOUNDED BY: 513004N 0000712W -
513014N 0000510W - 513003N 0000508W - 512952N 0000714W - 513004N 0000712W (SOUTHWARK).
BEYOND VISUAL LINE OF SIGHT UAS OPS CONTAINED WHOLLY WI THE TRA. EMERG SVC AND MIL OPS
REQUIRING IMMEDIATE ACCESS TO THE TRA SHOULD CONTACT HEATHROW RADAR ON 125.625 MHZ.
FOR OTHER CREWED ACFT OR VISUAL LINE OF SIGHT OPS ACCESS, CONTACT THE OPERATOR 72
HOURS PRIOR TO OPS COMMENCING ON 020 4592 3223. FURTHER DETAILS VIA: WWW.NATS-UK.EADIT.
COM/. AIC Y166/24 REFERS. AR-2024-3782/AU2. SFC - 450FT AMSL, 20 JAN 09:00 2025
UNTIL 20 JAN 16:00 2025. CREATED: 17 JAN 09:25 2025”
The idiot answer is
This NOTAM (Notice to Airmen) indicates a temporary reserved area (TRA) activation in Southwark, London. The TRA will be active on January 20, 2025, from 09:00 to 16:00, with altitude limits from the surface (SFC) to 450 feet above mean sea level (AMSL). The area is bounded by specific coordinates and is designated for beyond visual line of sight (BVLOS) unmanned aircraft system (UAS) operations. Emergency services and military operations requiring immediate access should contact Heathrow Radar on 125.625 MHz. For other crewed aircraft or visual line of sight (VLOS) operations, access requires contacting the operator 72 hours prior to operations commencing on 020 4592 3223. Further details can be found on the NATS UK website.
Use Drone Scene
Some dude is planning to fly beyond visual line of sight the whole day.
If they are legally flying BVLOS then I’ld imagine they are serious as that authorisation isnt easy to come by.
I’ld try to postpone your job to be on the extra safe side.
Notaminfo.com/uk might have more info along with dronescene ofc if you cant change dates.
Thanks, i will keep trying NATS too, as a very limited area and time i’d be flying, just to check.
I keep getting their answerphone, stupid question, but are they normally accessible on weekends? Never had to deal with them before.
Me neither,
I’ld assume they are office hours based so not at the weekend.
I tend to file a flightplan with my details attached and hope i dont get a phone call :slight_smile:
Maybe you can designate a competent person as an oberserver to add another layer of bum covering along with a flight log?
I’m sure there are others here that have more experience in these situations. I’m just a bumbling amateur waiting for some hawks to bugger off so i can fly.
No worries,appreciate the advice.
Looks like that restriction is in place at least all of next week, so makes you wonder exactly what is happening.
Just looking, for another job in another area next week, despite drone assist showing no issues, elsewhere i’m seeing a load of messages like this, again, assume that means no flying?
“D: J4647/24
Type: RESTRICTIONS (ACTIVATED)
Period: 2024-12-23 12:20 to 2025-03-23 12:00 Sched:
Limits: SFC to FL023
RESTRICTED AREA (TEMPORARY) ACTIVE FOR UAS ONLY (MOLESWORTH) WI 2NM RADIUS OF PSN 522312N 0002508W DOES NOT APPLY TO ANY UAS FLYING IN ACCORDANCE WITH EXCEPTIONS STATED IN THE BRIEFING SHEET. A BRIEFING SHEET REFERS. FURTHER DETAILS WWW.NATS.AERO/AIS. RESTRICTION OF FLYING REGULATIONS MADE UNDER ARTICLE 239 OF AIR NAV ORDER 2016. AR-2024-8633. SFC - 2300FT AMSL, 23 DEC 12:20 2024 UNTIL 23 MAR 12:00 2025. CREATED: 23 DEC 12:35 2024”
That’s probably to do with some of the other air restrictions in place at the moment near & over military places, some are mentioned in this Thread Here in the uk :+1:
Ditch drone assist, seriously
Seems the best plan! What’s the best place for checking for restrictions?
Thanks Kirky, yes could well be. Assuming the best plan is to call NATS to seek permission?
You could give it go calling them to seek permission but not sure how strict there being at present, my local lake where I sometimes fly is covered with a temporary extended restriction till the same date as the one you posted which is Burgfield AWE .
Yes I am wondering, especially as on this one, there are about 6 different restrictions listed.
Dronescene is the only site you need. It’s been developed for drone enthusiasts, by drone enthusiasts. Seriously, it’s all you need. And you already have it as you’re an insured member, no more guessing! Have any questions about it? Ask in here for a pretty much immediate response from members and the developers. Try gettting a response from the others within 24 hours never mind 30 minutes!!!
:point_up_2:
Dronescene isnt alone with not always being upto date, Drone assist is another example. no fault of the site. Some information just isnt polled completely, eg all notam’s.
Imo best to check multiple sources as mentioned already when your dealing with this sort of thing.
Both recommended by the CAA, both get data from the same place.
:man_shrugging:
Both locations i’ve checked on Dronescene and neither list the restrictions
Seems the best plan, thanks Nik
