Keep getting nagged about this. As I do the software update and firmware update, which I am definitely NOT doing!!! Any point in updating the flysafe database? I personally think not.
All depends if you have the NFZ hacks.
No I dont, just the fcc from drone tweaks
Shouldn’t make much of a difference then.
Completely up to you
Not sure if this is true, as the Dronehacks apply’s a Unlock Certificate to the Drone via bespoke firmware which unlocks all the GEO Zones independent of the version of the fly safe database … I think
It does Wayne.
What I meant was, if you have the NFZ it’s a waste of time anyway.
Other than that it’s up to you
What is your opinion of the fcc hack? Is it worth the price?
I have the drone tweaks fcc software hack. I have to say it works fantastic and is definitely worth it. I don’t use it for the extra distance, more for urban areas to cut through all the noise.
