Focus issues on Air 3
Anyone else have issues with focus on the Air3 ?
Was taking some images of some guttering on a roof the other day and , in autofocus, even when tapping on the gutter on the screen, still producing images like this.
Only way is to switch to manual i guess?
Might be there’s not enough contrast for autofocus to work if your aiming it in the gutter, try edge or something at same distance then re frame your shot. If you stop down a little it will increase your depth of field.
Thanks, yeah I probably need to play with it more, just not something i’ve experienced before. Mainly seems to be on the 70mm lens too
You may be a little too close for telephoto, what’s the minimum focus distance?
Good point, i’ll have a look
Ah yes, 3m on the telephoto lens!
