Congratulations to @notveryprettyboy for his winning Rubik’s cube entry.
He has chosen the next trick to be the GRIND
Hang on, that’s not it. It’s similar to the skateboard grind. You fly your quad along a beam, railing etc. Keeping contact whilst moving forward.
Erm…
Yes, that’s it. Only with your drone.
INPORTANT. Turn off airmode. Have it on a switch, or off altogether. If you have it on, you’ll bounce like a kangaroo on a trampoline.
This trick will run until the start of February next year because of the shorter days.
Tutorial is attached to this message, which will self destruct with the next major solar flare.
Good luck!
Yith
12 November 2022 18:55
2
Ok… Where the heck will we find a suitable grinding location?
I assume @notveryprettyboy has some ideas?
A car park that has railings? Use a sub 250g @bigdog special
Earwig
12 November 2022 19:06
5
Local skate park? As long as it’s clear of yoofs, that is.
Yith
12 November 2022 20:48
6
Er… where there?
I’m not doing it on the viaduct!
Yith
7
This is all I can think of!
I’m going all in on this. A grind, lift off, yaw 180 then grind backwards. That’ll look mint
You can grind on almost any flatish surface, shouldnt be hard to find somewhere
This thread made my night
BigDog
13 November 2022 10:14
12
Typical they have a tone of handrails where I was at yesterday
Just dont fancy banging heads with Mr Mc Nasty again
Earwig
13 November 2022 16:51
13
BigDog:
Where was that, just out of interest?
He does look like a bit of a tool to be fair
mpaull
16 November 2022 11:25
15
Feeling positive about this competition…
mpaull
16 November 2022 11:28
16
That’s what’ll happen to my bank balance if I try this
mpaull
16 November 2022 14:34
17
Having just jinxed myself is it normal to feel everything from laughter to turning the air blue with this FPV malarkey?
Today’s learning curve: The motors don’t easily shut down on DJI products. The other here is the result of Turtle Mode. Something else I won’t be trying again!
yeah not great on grass especially wet grass lol
