Congratulation’s & well done @ORB_FPV it’s time for you to decide the next challenge for your fellow competitors, post it here along with any rules you want to apply ie, name of the challenge, time length duration to complete the task, tricks etc then challenges committee shall set it up in a new thread.
Thank you !
Also a big thank you to all those that made an entry well done all
Dear fellow FPV pilots, you guys rock!
Here is my suggested next challenge, growing a bit from the previous one, but not going full out yet!
THE EIGHT-BALL
I would like you to have two objects (trees / poles or similar) spaced from each other 5-15m, away from people. The challenge is to fly ACRO smoothly around the two objects creating at least 3 figure of eight in a row. The key part of the challenge is throttle control - make sure that you go as fast as you feel comfortable with, but remain as much parallel (and therefore constant altitude) to the ground as possible - between 30cm and 4-5 meters max.
BONUS POINTS: on who manages to turn around the objects facing the sky (once or more), instead of the ground (!)
DURATION: one month, at the discretion of the committee.
Other Rules - same as Orbit your POI
Enjoy!
yes it does - but you need the FPV controller 3 and compatible goggles for it. You also have to do a “mod” to the throttle stick on the controller so that the spring has no tension on it. ( loads of YouTube vids about that ) once done you will have Normal - Sports and Manual Mode ( normal and sports will be like flying any other drone really )
Thats great news because I do have the motion controller.
However, the total time that I have flown using my new goggles and motion controller is minimal, so I’m using this challenge as the steepest learning curve ever. Should make for some funny videos anyway.
Someone has to come last don’t they?
I’m looking forward to doing this now.
