GADC Fpv Challenge - The Split S! - Vote For The Winner
cool list!
As bugged by @ORB_FPV
Terrible Split-S with a very small whoop.
Date: 2026-01-18. Location: South London.
Aircraft: betafpv meteor75 walksnail
+1 for the soundtrack :smiley:
Here is my entry (I needed as much practice as possible :slight_smile: )
Location - my kitchen yesterday evening :slight_smile:
Mobula 6 HDZero
THIS CHALLENGE IS NOW CLOSED FOR ENTRIES
Poll shall follow shortly to cast your votes !
The FPV Challenge is now closed to entries - so it’s time to vote for your favourite, You have one vote each & they are in no particular order set out below, ’ DO NOT VOTE ‘ for your own entry or it will be disqualified, the poll closes at 22:00 on Tuesday 27th January when you will find out who has taken the top place !
First Place Winner Gets To Choose The Next Challenge, so while the poll is running it maybe worth all those that entered having a think about what challenge you may set if you win so we can then get the new one up & running asap,
however, should there be a tie a poll shall be set up for a further 24 hours to cast first place winner,
Good Luck All ! :slightly_smiling_face:
@group-challenges @group-fpv
we have a tie… :innocent: :smiley:
congrats to @ORB_FPV - I trust you have the next challenge ready… chop chop :wink:
Congratulation’s & well done @ORB_FPV it’s time for you to decide the next challenge for your fellow competitors ( no rush ), post it here along with any rules you want to apply ie, name of the challenge, time length duration to complete the task, tricks etc then challenges committee shall set it up in a new thread.
Thank you !
Smashed it @ORB_FPV well done man
Dear all, let’s keep it simple and basic still - we have plenty of time to go to the power loops, wall rides and other fun challenges.
The challenge I suggest will have a few advantages
  • get to know the inertia of your quad
  • understand your rates (THIS IS KEY for acro :slight_smile: ) if you want more information on that specific - just ask - imho, the best way to understand that for those of you who are starting and using standard rates, is to try in simulators)
So the next challenge is “Ctrl-Z”, in which you need to do an inverted loopback.
An inverted lookback in FPV acro is a freestyle trick where the pilot flies high, flips the drone completely upside down (180-degree pitch) while maintaining forward momentum, holds that inverted position while looking “back” at where they came from, and then completes the flip to upright. It is a segmented, graceful maneuver that, when done correctly, combines high-speed movement with a momentary, gravity-defying “float” while upside down.
The video can be cut or a whole pack, but try to say where the figure you submit is (timecode).
Example: https://www.youtube.com/watch?v=zsOiLwK0NCQ
Now this is interesting for beginner, intermediate and advanced pilots. The better you are, the lower, faster and most important the LONGER (cough cough - don’t forget Grey Arrows has a dedicated crash thread… don’t erase your video by shame! :-D) you should execute it. If you are not confident, just make sure you have enough speed (and altitude!!!) to give this inverted floating impression and good rates to stop as perfectly horizontal as you can.
Make sure you do it on a flat land and far away from anyone or from trees…!
Can I leave it to you @Challenges_Committee to define standard timelines and usual rules?
No problem shall be set up shortly ! :slightly_smiling_face:
Be interesting with a whoop they dont really have that intertia might have to break out the 3.5 and do some sbang
good point, I thought about this when I put the challenge - but it is a really good way to learn for FPV quads (at least 3’’ and more).
It is indeed a disadvantage if you fly whoops - sorry for that.
If it affects a lot of you guys, I don’t want to push you out of the challenge, so could change it to something else.
Its doable with a whoop just might be a little snappier is all, im at bird this weekend so will be spending a load of time on the sticks with whoops , if you power in with it it should be fine
